RCU Forums - View Single Post - double elevator servo Hookup?
Old 08-02-2006 | 09:17 PM
forestroke's Avatar
forestroke
Default RE: double elevator servo Hookup?
yeah. split elevators is a pain for those that don't have a nine channel radio. my hitec eclipse seven channel doesn't support split elevators. technically you can do it but if you accidentally move the ch. 7 dial just a click, the elevators aren't even and can easily lead to havoc in the sky (soon the ground). i assume that for some other radio's you can turn off the dials you don't use or that there may be a special mode for split elevators.
anyway, i think that unless you have to have two elevator servos (for torque and short linkages) i prefer the bellcrank, the U shaped wire or the Y control rods.
the servo mod, while not difficult, does give you something extra to worry about!
good luck!!!
