RE: Can your ARF do this ??? Not easy but possible, check this out !!!!
I'll bet you don't step on cracks in the sidewalk or walk under ladders..... If you stay in the parameters set forth by the AMA you will not be in conflict with the almighty FAA........ Do not fly ANY model aircraft beyond YOUR unaided line of sight. No autononomous flight means that the aircraft has to have some ground control, not a pre-programed flight plan that allows it to fly alone. There is a fellow in Fla. that has been flying his plane using an on board camera and he watching a monitor, for at least two years with NOT ONE problem with either the AMA or the FAA.....Check out RC Report Magazine page 99 orf the August issue. Why dream up problems that don't exist?? Just relax and have fun,,your shadow won't bite....Cliff 'nuf said.
