Originally posted by RCU
Hi Chad, what did you do to work out the problem with the 225's and flutter? I've been in the shop and not online much.
JW
i finally ended up moving the clevis farther away from the control surface to give it more of a lever advantage and the problem was solved. i figure that with the slack of a metal gear (typical) that it was just amplified with the clevis real close to the control surface.
Chad
