RCU Forums - View Single Post - Wing ID
Thread: Wing ID
Old 08-04-2006 | 08:53 AM
fizzwater2
My Feedback: (61)
Default RE: Wing ID
OK - here's some pics (if this works out correctly).. The plane is the one in question, left and right side views. The belly pan is a full-width pan, not a skinny "fin" on the bottom of the wing to make height. The LG bolts to the wing directly, two pieces.
The wingtip and wing pic are one of the two wings I have, don't know what it's from. This one has a narrow ridge, fin, whatever, on the bottom to make minimum fuse height.
The other wing I don't have pics of - it's a straight TE, swept LE with tips that are round in front, meet the TE at pretty close to a 90 deg angle. I'm pretty sure it's intended for a low wing, the LG again mounts to the wing in two pieces, and it's got some dihedral molded in. It's got topside skin hinges molded in, also. I'll try for pics of it later, but like I said, I had to go to work..
The tail pic I just thought I'd throw in here, even though it's a Q500. It's a v-tail, with the V sort of buried in the fuse sides, rather than on top in a saddle. Anyone know what that might be? Too bad about the hangar rash on the LE of the right side tail, otherwise the plane's in great shape.
Thanks again, guys, and I hope these pictures work out!
ID:	501539   Click image for larger version
ID:	501540   Click image for larger version
ID:	501541   Click image for larger version
ID:	501542   Click image for larger version
