RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 08-04-2006 | 09:06 PM
  #4578
Adam G's Avatar
Adam G
My Feedback: (17)
Default RE: Hangar 9 Twist 3D
Dutch,
Congratulations on the successful maiden of your Twist. If you like slow flight you may want to consider switching to a a 12.25x3.75 prop. I think that is what the guys are using for more 3d style flight. Maybe one of the .46 guys can chime in and confirm what is the proper sized 3d prop for the .46. I know that when I went to a higher diameter and lower pitch prop on my .61 (12x8 to 14x4) it really changed the flight characteristic for the better. My Twist doesn't like speed anyway with those huge control surfaces and extreme throws I have programmed in. You should be able to hover no problem witht the proper prop on that OS .46. Welcome to the club!
Adam
