RCU Forums - View Single Post - moki 1.8 flame out
Old 08-04-2006 | 10:50 PM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: moki 1.8 flame out
Make sure that the hole in the Cline is not getting blasted by air. This air blast from flying can richen the Cline and make your engine run rich. May not be the problem but worth checking. The Cline is the same exact device used by gassers for the metering device and has this problem of air hitting it. You could try making sure the hole is not getting hit with direct air by shielding it. Make sure it's open to air but shielded from air blast. Mine richens in knife edge right to left but is fine in knife edge left to right. I haven't tried shielding mine yet. I'll let you know when I try it.
ORIGINAL: Phantom Phixer
I have a moki 1.8 in a midwest cap 232, 80". The Cap was built by Mike Ramsey and on the cover of flying models in 97.....I purchased it from Mike 3 years ago.
The fuel tank is 24 oz, and I'm using FAI fuel with a cline regulator and an OS 8 plug with an 18 x 8 carbon fiber prop.........and pitts muffler
the motor runs fine on the ground...smooth idle, really smooth for this thing and transition is great and top end is right on spec for motor / prop accoring to article by clarence lee.
just rebuit the cline regulator per thread on RCU........no heat problems.....and NO lean runs
problem is in a humpty bump, large loop, hanner head....it either coughs or dies........
now being this motor is supplied by a pressured system......I wouldn't have believed this could happen..............first things first..............checked fuel by changing the jug.....easiest........checked the clunk.........no problem there...........the hole on the cline to equalize the bladder is open....fuel lines are OK.......
If I fly real easy....rolls, knife edge, small loops, and 4 point rolls it taxis back to the pitts.....but turn inverted and do an immelman and look out...........
I'm beginning to think I'm missing something real simple.....
any suggestions are appreciated
bob
