RCU Forums - View Single Post - T34 Smoke Unit
Old 08-05-2006 | 08:58 PM
sownare
Default T34 Smoke Unit
Here's the setup for my t34 smoke unit. I'm using a y-harness for the DMD's throttle channel and the electronic speed control. The setup is very effective. Clean, quiet and plenty of smoke. Looks great when the tank turns into it's smoke. The downside is that power consumption is very high. I have two sub-c 7.2volt battery packs. The tank's run time is 15 minutes. Any leads on sub-c battery packs with a higher capacity rating? Thanks!!
ID:	502179   Click image for larger version
ID:	502180   Click image for larger version
ID:	502181   Click image for larger version
ID:	502182   Click image for larger version
