RCU Forums - View Single Post - Comp-ARF Mig 15
Old 08-06-2006 | 02:59 AM
JET FX's Avatar
JET FX
Default RE: Comp-ARF Mig 15
ORIGINAL: Vincent
Marty,
My little outer doors are screwed down and have a slot cut in them so the struts clear. My wing tanks hide the door anyway so its not even noticeable when my gear are down. V..
Vin you cheat that sounds way too sensible... maybe I should add the tanks to my one it would save a lot of headaches as my set up aint ideal and has come loose on a couple of harder landings, I agree that you would not even notice the outer doors then with tanks fitted as you did, do you have any pics of your door set up?..... I wonder if anyone has done the smaller slipper style wing tanks for this Mig (see pic below) as they do appeal to me, sort of unique to Migs also, I might just make some I think
ID:	502322   Click image for larger version
