RCU Forums - View Single Post - shift...nooo..work help
Old 08-06-2006 | 07:25 AM
chubbysuncle
Default RE: shift...nooo..work help
nbluehell Date 8/5/2006 6:50:40 PM
oh this is very important. behind the adj. screw there is a spring and a ball bearing. if, like i said before, you adjust the srew out too far it may fall out and you may loose the spring, ball bearing and screw.
I told ya! Clean out the clutch with air and lube it up first. It should shift. If it still doesn't and you've got a good tune on the engine, take the trans apart, remove the clutch and clean it. Take it apart and you'll see how it works. Make sure when you reinstall the grub screws to use Blue Locktite!
