RE: Need help with Y/A F-18 Single
Here is what the instructions say.....
Ailerons...........5/8 Up and Down
Elevator.........High rate....1 1/4" Up and Down
Low rate.....3/4" Up and Down
Flaps..............Landing.....50 degrees
Take off.....20 degrees
Rudder...........3/4" Left and Right
CG is located at 12 1/2" forward of the Trailing Edge of the wing at the root. the elevator servo is the first one from right to left in the picture and the rudder servo is installed right behind.
Hornet 1
