RCU Forums - View Single Post - Kaos 60 Control Throws
Old 08-06-2006 | 05:42 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Kaos 60 Control Throws
Reduce the up elevator, but leave the down. If you are going to do outside loops and maneuvers, you'll need more down than up elevator.
Low wing planes with a high stab are more sensitive to up elevator then down so to make the response equal, you'll need more down.
Conversely, for a Stick or other high wing plane, you'll find the down elevator is more responsive so you'll need less down elevator movement on them.
