Evolution 58 reeds?
Got my 58 back after it went in for a blown gasket between the cylinder and crank.
Horizon replaced the gasket and ignition.
Tried to run it today, would not start at all, not even a pop.
Checked for a spark and its there,Gas in the line, choke works correctly in fact nothing changed from peviously.
I then noticed that when I flip it makes a weezing sound and fuel pours out the carb, with or without choke and even after it sits for a while.
So I assumed it was flooded but on pulling the plug it seems pretty dry.
looking thru the intake the reeds look okay but turning it over it seems that the intake is blowing out air as you turn it over???
Its under warranty and Im to tired and hot and cranky to mess much further.
any ideas??????
