RE: stater pattern
The Excelleron and Quest are the two main planes that come to mind that would do as a 90 ARF size pattern plane for the $$ mentioned. If you dont mind doing a little builing the CA Models Widebody or Epsilon can be had for about 200.00 and build quick and straight and are excellent flyers. There is a Widebody thread out here in the pattern forum if you'd like more info on the plane. Good Luck!!!
