RCU Forums - View Single Post - Need advice on Fuel fill adapter
Old 01-04-2003 | 04:45 PM
Whirley Bird
Default Need advice on Fuel fill adapter
Hi Gang,
I have a trainer here RTF.
Flies well and no problems.
I have to remove the line from the carb to fill the tank.
A real PITA!!!
I see where they have an adapter to install and comes with a check valve so you don't pump fuel into the carb.
The fuel tank is glued in place and I can't see cutting up the top or the side to install a small fitting with a nipple on it.
Has anyone ever installed one of these on a Super Star Select 40?
If I could remove the fuel tank then I can just run my own fill tube then cap it.
Any tips,suggestions
