RCU Forums - View Single Post - 2 blade to a 3 bladed prop
Old 08-08-2006 | 03:52 PM
TLH101's Avatar
TLH101
My Feedback: (90)
Default RE: 2 blade to a 3 bladed prop
If you power at the lower end of the power range, you will have problems with a 3-blade, however if you are using recommended max power, a 3-blade should be fine. Just drop 1" in pitch, or diameter from your 2 blade that flys the model best. Do not start with a 3-blade unless you really know what prop you want.
