RCU Forums - View Single Post - shift...nooo..work help
Old 08-08-2006 | 06:11 PM
chubbysuncle
Default RE: shift...nooo..work help
Are you talking about the small set screws in the second gear clutch? If so one in the center of the clutch holds it on the shaft, The other one is slighty offset of center. This has a small spring and ball bearing under it. This is the one that adjusts the shift point.
