RCU Forums - View Single Post - backup motor
Thread: backup motor
Old 08-08-2006 | 07:31 PM
aangelet
Default RE: backup motor
If you run a small to medium track, the P5X will be perfect. If you run a medium to large track, the Plus 21-5 might be preferable. The C6 is just crazy and is hard to control. If all you do is run a small track, then an O.S. RG is all you'll need and your lap times probably won't do down as compared to your times with the V-Spec.
