RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
View Poll Results: A poll
rb c6 bb
28.00%
axe rossi cobra
4.00%
nova p5x
28.00%
ninja
24.00%
radical 621p
0
0%
max power mb5
4.00%
other (specify)
12.00%
Voters: 25. You may not vote on this poll
backup motor
Old 08-07-2006 | 08:31 PM
Default backup motor
im just looking to pick up an extra engine for when my v-spec (which is absolutely awesome at the moment) dies. because of the bearing thing i think it is probably best to have a spare handy. also will my os 2060 pipe work ok with any of these motors. (it absolutly screams on my v-spec)
Old 08-08-2006 | 04:11 PM
Default RE: backup motor
Have you thought about the novarossi 21-plus 5. It would be a good match performance wise for the v-spec. I have a new engine on its way that i have been told would be a good partner to go with my v-specs i'll let you what it like when i get it.
p.s. I have now replaced to rear bearing in my v-specs both at about 2-4 gallons i replace the first one with a boca bearing and the second with a novarossi. The boca last for the rest of the motor the novarossi is still going strong but it wasn't replaced that long ago.
In response to the post below, i've driven a 21-plus-5 briefly to see what it drives like vs a v-spec. I have no experience with it bar that. i just put that suggestion out there as i love how the v-spec drives and the 21-plus-5 drives similar, so yeah obviously get some opinions on it if you want something that drive like a v-spec.
Old 08-08-2006 | 04:24 PM
1CE
unless you are a serious racer (which you could be) dont you want a cheaper back up motor like a rg or somthing? Theres a guy in my club that races with an rg and is in the a main almost every race night. But if you NEED the power go for it. Those are just pricy motors
i fergot to add that a few guys localy have tried the 21-plus 5 and have had bad luck with it. it wont idle, runs hot then cold. we checked for leaks and everything the motor is just weird. These guys are experianced too so its not a tuning problem just thought i would tell ya that. The last thing you need is a backup motor that is a pain.
Old 08-08-2006 | 04:43 PM
yea i would like one of the pricy motors. i just got done with my first 1/8 scale race ever this past weekend and this is a very fun class. i came in third first time out. so im focusing all of my attention (and money) twords my xb8 tq. all of the ppl at my track are running p5x's rb's no c6 yet though and v-specs. and most are using jp 2 or 3 pipes.
Old 08-08-2006 | 05:24 PM
RCtruckRacer's Avatar
I'd go with the RB WS7 III
Old 08-08-2006 | 05:33 PM
mkincy's Avatar
if you do get the C6 i highly recomend geting the RB 2045 pipe to go with it. i've tryed the jp2 with my C6, it just wasnt as good a match as the 2045. the rb pipe just seems to squeeze every drop of power from the engine. also i went from 8 min with the jp2 to 9 min with the 2045 runtime.
Old 08-08-2006 | 07:10 PM
ORIGINAL: RCtruckRacer
i was thinking about it but someone at the track had one and the touque just wasn't there. i will try my os pipe first and if it doesn't work good then i will get the rb pipe. i would like to try not to buy a new pipe for every engine lol. $150 for my os pipe it better work with everything.
Old 08-08-2006 | 07:31 PM
If you run a small to medium track, the P5X will be perfect. If you run a medium to large track, the Plus 21-5 might be preferable. The C6 is just crazy and is hard to control. If all you do is run a small track, then an O.S. RG is all you'll need and your lap times probably won't do down as compared to your times with the V-Spec.
Old 08-08-2006 | 07:47 PM
see the thing is im not going to be staying on just one track. and even the track i am at most changes quite often. so my v-spec is good because it has great top and bottom end. what is the c6 like though because i have heard that is has similar characteristics as far as balaced power goes. this motor will eventually end up being my main motor when my v-spec takes a crap.
Old 08-08-2006 | 10:36 PM
Why not buy another V-Spec. Thats my spare When the one in my car dies. I pop in the new one.
Old 08-09-2006 | 12:15 AM
Hincappe's Avatar
OS OS OS OS OS
why have a $400 backup motor? why not have anothe vspec backup? its only $240 and is way better than any of those listed!!!!
Old 08-09-2006 | 04:31 AM
Coopz's Avatar
Vspecs are excellent, but unless your track has ultra long straights engine power doesn't equate to much.
Old 08-09-2006 | 06:05 AM
Hincappe's Avatar
huh? vspec does everything perfect. awesome bottom mid and top. there are no weaknesses. as shown by race results all around the world. if a buggy won as many races as the vspec, then we would all say that buggy is the best.
it took me a long time to buy a vspec, and after having bought one i would buy nothing else.
Old 08-09-2006 | 06:43 AM
would a modifed v-spec be less prone to bearing failure?
Old 08-09-2006 | 07:11 AM
mkincy's Avatar
ORIGINAL: darthballs
yes, the modded vspecs have had the bearings replaced.
Old 08-09-2006 | 07:59 AM
oh ok then i will probably go with that. just have to save up for a little longer. so which one then is the jp worth the extra 40 dollars over the eb
Old 08-09-2006 | 08:31 AM
Coopz's Avatar
2 litres through mine now still using the orginal plug
Old 08-09-2006 | 09:39 AM
same here im still running origional everything and im at 3/4 of a gallon and going strong but i hear 2 gallons is about when they fail.
Old 08-09-2006 | 05:33 PM
The JP Mod is a limited production model. 300 engine's. Only 100 piston/sleeve/rod combo's made. I just bought P/S/R combo for mine from RCNITRONATION.com. Good engine. the EB Mod is also very good. They are both worth extra buck's. The mods seem to limit the life of piston and sleeve. About 2 gallons's when run at top performance continually. I have 3 V-spec's running right now. 2 are RB mods. I have one that has 15 gallons through it. I just put its 3rd P/S/R in and replaced the original front bearing. I will keep it as a spare, until time to rebuild one of the other's.
Old 08-09-2006 | 07:27 PM
k so i think i will get the eb mods then it is considerably cheaper. i already have the power i need im just looking for the bearing done. and a little bit of longevity.
Old 08-09-2006 | 07:34 PM
have you thought about sts team motor they are really good motors at half the price
Old 08-09-2006 | 08:47 PM
no can't say i have though about one. lol budget is not one of my main concerns. i will find a way to get the cash (i usually figure something out) . plus having an uber motor like i do now is great. so i will just stick to a v-spec just a modified one.
