RCU Forums - View Single Post - vibration
Thread: vibration
Old 04-24-2003 | 01:43 AM
Joe K
Default vibration
I found that the rotor head with out the blades was way off.
I ended up drilling a hole in both grips and putting in a screw and nut on it to get it in balance.
I just took the whole rotor head and putting it on the highpoint.
If you have a spare main shaft use it. Or you can use a piano wire the same diameter.
