RCU Forums - View Single Post - Hirobo ZXX 30 size engine problems?
Old 01-07-2003 | 02:30 PM
Culverson's Avatar
Culverson
My Feedback: (14)
Default Hirobo ZXX 30 size engine problems?
If it is a ringed version some have lower compression on start-up to counter starting issues like seen on some ABC larger engine which can be rough on your starter shafts. But it sounds like you need to check-re-torque all engine bolts especially head bolts and go from there. If it really seems to have a loss of compression you might need to tear-down and check the ring in F series and if ringed version of newer OS, or if ABC which most are on newer engines look at the piston & sleeve to look for damage or wear and check to see if you need a piston or liner or ring..according to if it's ringed or ABC type engine..
This is after you exhaust all other issues addressed here first..
