Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Hirobo ZXX 30 size engine problems? >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 01-04-2003 | 11:45 PM
My Feedback: (17)
Default Hirobo ZXX 30 size engine problems?
What would cause a 30 size engine to lose compression in the middle of running. I am pretty sure that it was not too lean. I am running 15% cool power fuel in it, and it was running good enough to fly 2 days ago. Thanks for any help you could give.
Old 01-05-2003 | 01:56 AM
Check your clunk line it may have colapsed.
Old 01-05-2003 | 03:24 PM
My Feedback: (17)
Default clunk line colapse?
I wouldn't think that a colasped clunk line would cause the engine compression to go away? There is still no compression even after it was off. Engine will not start.
Old 01-05-2003 | 03:57 PM
check your head bolts but it sounds like lean running has killed this one
Old 01-05-2003 | 05:56 PM
I had a heli that the clunk line colapsed and the engine leaned out enough to sieze the motor before I could get it on the ground. It messed the sleeve up and thus the loss of compression.
I would hate for you to get the engine fixed and have the clunk line ruin another.
Old 01-07-2003 | 02:30 PM
Culverson's Avatar
My Feedback: (14)
If it is a ringed version some have lower compression on start-up to counter starting issues like seen on some ABC larger engine which can be rough on your starter shafts. But it sounds like you need to check-re-torque all engine bolts especially head bolts and go from there. If it really seems to have a loss of compression you might need to tear-down and check the ring in F series and if ringed version of newer OS, or if ABC which most are on newer engines look at the piston & sleeve to look for damage or wear and check to see if you need a piston or liner or ring..according to if it's ringed or ABC type engine..
This is after you exhaust all other issues addressed here first..
Old 01-10-2003 | 06:12 PM
My Feedback: (17)
Default Engine is DEAD!
Upon taking this engine apart to see what was wrong, I found that the ring had broken. Killed the piston, ring and rod. To replace these parts will cost about $70, so it looks like I will be purchasing a new engine. Cylinder was ok, believe it or not. Anyone have an engine that they want to sell me resonable. LOL
Thanks for the input.
