RCU Forums - View Single Post - Glinder with 4.0cc engine
Old 08-10-2006 | 10:26 AM
reinoks
Default Glinder with 4.0cc engine
Handmade glinder with 4.0cc engine ... is it good idea ? and where/how to put it ...
MY palne - lenght: about 130 cm weight: 600 g
wings - lenght: 200 cm weight: 300 g
My TRANSMITTER is only with 2 channels ( check my pofile )
yeah my sailpane is pretty light so i have to put some weight to it ...
point is that i dont have this starting rubber ... what ever ... so it costs about 30 $ - 60 $
for this money i can buy an engine what can add some speed to my plane ...so by this way i can get my glinder up to sky ...
i want to put/install/iaffix engine what i can start easly and maybe use in in the future
and yea about this 3. channel thing (gas setting) what ever i have very old diesel engine without this gas thing...
but this engine is so old that i cant start it [:'(]
and im not so dumm that i cant get that i can set trottles...
as i red from other forums (subforums)
4.0cc is too powerful ... it will cause rocket effect lol ... whatever
but maybe 2.5 cc is ok ?
15 LA (os engine)
and if ill put it on pane nose/top then i can get ths pane up to sky ?
pls comment
1. engine
Displacement: 4.07cc (0.249cu in)
Bore: 18mm (0.709" )
Stroke: 16mm (0.630" )
Output: 0.6 bhp @ 15,000rpm.
Practical rpm: 2,000 - 16,000rpm
Weight: 185.5g (6.54oz)
Crankshaft size: 6mm
Distance between mounting tabs: 1.89" (48mm)
Distance between mounting holes on opposite side: 1.46" (37mm)
Distance between mounting holes on same side: 0.59" (15mm)
Width of crankcase below mounting tabs: 1.10" (28.1mm)
Height from bottom of crankcase to top/cylinder head: 2.93" (74.4mm)
Length from end of crankshaft to backplate: 3.43" (87.1mm)
2. engine
Aluminum 1-piece crankcase, piston, cylinder head,
crankshaft, connecting rod, and crankshaft. Chrome-plated
Brass cylinder.
Bore: 18.0mm (.71" )
Stroke: 16.0mm (.63" )
Horsepower: 0.6 BHP at 15,000 RPM
Weight: 7.0 oz w/o muffler (9.5 oz w/ muffler)
Length: 67.5mm distance from backplate to front of drive washer
Width: 29mm width of engine neglecting engine mounting flanges.
36mm distance between the centers of mounting holes.
Height: 74.5mm
Crankshaft Thread Size: 1/4-28
Recommended Props: Break In: 9X5
Trainer and Sport Models: 9X5, 9X6
Scale Models: 9X5, 9X6, 10X5
Practical RPM Range: 2,500 - 16,000 RPM
if u now better/cheaper engine pls recoment ...
pls comment ...
ID:	505109   Click image for larger version
ID:	505110   Click image for larger version
