RCU Forums - View Single Post - Level Hovering
Old 08-10-2006 | 05:59 PM
twostep
Default Level Hovering
Ive just recently (about a week) been able to get my blade off the ground and hover at knee level thanks to Radds. Im also getting familiar with the proportion pot and gain but im still pretty new to it, so its still not perfectly the way i want it...
anyhow, i dont think my problem is a result of incorrect proportion or gain and i cant figure out what it may be. Once im airborn, i can keep the tail straight with a lil rudder input but the entire heli leans to the right.......it leans right as if its getting aeileron input to the right, or as if its heavier on the right than on the left. But when its on the ground, if i lift it by the flybar the blade is perfectly level except for the nose being a bit lower as the manual states.
My first major crash (before radds) resulted in a broken main frame assembly. So i followed Bdavisons assembly and put everything back the way it was with a new mainframe assembly. It seemed to be okay once reassembled, but im nowhere near to being a pro. The only thing i can think of is to check the swashplate, and the swashplate is level....
What else should i look at or look for?
If you have any suggestions please let me know.....
Oh, its the stock setup.....stock motor/blades (not the cp pro)
i have new blades on there.
new skids
theres no pitch on the flybar paddles (shouldnt matter, but just letting you know)
