RE: Koveral Appication
I have been doing great thanks for asking!!!
I always leave a couple inches or excess around the edges then put a coat of dope on the fabric and let it dry then it will not fray when you trim it. Once you get it trimmed dope the edge down. I apply 5 to 6 coats of dope over the fabric at the seams, lightly sand after the 2nd coat and between each coat after that. Make sure you do not sand into the fabric. Any fuzz you are seeing should sand off. I would use 320 or 400 grit paper for the sanding. Once you get everything sanded and sealed you will have a very hard time finding the seams if it is done properly. It is really a easy process to learn and get great results.
I will keep an eye on the thread and see how your doing.
Later!!
Anthony
