RCU Forums - View Single Post - Jet tubes
Thread: Jet tubes
Old 08-11-2006 | 05:20 AM
Miniflyer
Default RE: Jet tubes
Optimum distance varies with turbine and install. Best bet is to make a thrust tube un which the location can easily be adjusted, and to work out best thrust/temp ratings by trial and error. Will cost about 2 liters of fuel and half an hour work, but will set you up with the distance that works best your specific plane.
Best regards
Hank
