Jet tubes
Does anyone know the optmimal distance between the turbine exhaust and the start of the jet tube? I am building a PJP Jets 1/6th scale Hawk with a Simjet 75 N turbine?
Optimum distance varies with turbine and install. Best bet is to make a thrust tube un which the location can easily be adjusted, and to work out best thrust/temp ratings by trial and error. Will cost about 2 liters of fuel and half an hour work, but will set you up with the distance that works best your specific plane.
Best regards
Hank
Best regards
Hank
ORIGINAL: quentinmayberry
what is it the 1200?
keep about 3 fingers of space between pipe and end of exhaust
