RCU Forums - View Single Post - Airfoil for F3A
Old 08-11-2006 | 08:40 PM
onewasp
Default RE: Airfoil for F3A
"planform" is normally the outline of the plane if viewed from above-----as most aircraft plans are presented this way it becomes the "planform" view.
"Section" is another way of referring to the airfoil chosen. If you took a completed wing and cut vertically through it and then viewed the cut from its side you have a "section". It means the same as the airfoil outline.
Hope this helps.
