RE: Setting gain and prop'l on CP
When I set mine I adjusted the Proporational to stop the nose from going to the left or right while hovering with the rudder trim in the netural postion. ( Now this will change as your battery drains down). I set mine with a fully charged battery and adjust the rudder trim as it drains down. I set the gain by increasing it until the tail would hunt,(Wag a little) then I turned it back down until it just stops.
