Clutch bell steel gears
Hello,
Are there any clutch bell steel gears for the Magnum?
the problem is that a friend of mine just keeps eating the spurs on the clutch bell...he has steel spur gears..the ones on the clutch bell are alluminum.
At firts he had the plastic stock ones..but they kept strpping no matter what..he changed them to steel and now the gears on the clutch bell are stripping....
Believe me..we have checked all....tried different methods we found on the net to adjust the gear mesh..we checked for bent shafts...and he even bought aother motor...we still have the same results.....
any now ideas on hoe to solve this problem?....or are there any steel gears for the clutch bell? . Now i think this is not a good idea since the problem will move to another piece for sure....well...anything will help
thanks
Elias
PD: i also own a Magnum....i've dissasembled it several times with no stripping problems at all..so we know how to adjust the gear mesh..
