RE: RealFlight G3 Add-on problems
Did you guys try the links in Jaafit's message?
The only problem I had with Add-on 1&2 was the serial numbers. With G2 you just used the G2 serial number. But with G3 you need a new number. The links above point to the numbers you need to install.
Carl
