RE: trouble tuning engine,need help
it sounds like it is running lean does it bog when you start to take off if so your bottom could be and if it takes off good and bogs when your starting to get speed then your top is lean i would go back to the factor settings get you hsn first and then do the lsn and you pinch the gas line when its warm.i would say the temp should be around 220-260 i ant sure for that motor. hope this helps you
