RE: Re-drilling CF Props?
what size prop is it ? which motor? if its up to a 100cc engine, the prop pattern is same on 3w and zdz, only the zdz uses 4mm prop bolts instead of 5mm like the 3w, and you can use the same holes even though they are 5mm and the zdz prop bolts are 4mm no prob.
