RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 08-15-2006 | 03:53 PM
  #71
Crazy4Flight's Avatar
Crazy4Flight
My Feedback: (540)
Default RE: Nitro models pusher Bobcat?
ORIGINAL: rcavi8ter
Does anyone have a good interior fuse shot of this aircraft? How is the quality of the fuse?
all formers are laser cut and appear to be glued in well. The fuse seems a bit heavy glass is a lot thicker than My Kangaroo. Also the is a plywood plate on the inside at the wing root. Holes note cut for the servo leads but they the cut lines are molded in, the anti rotation pin hole for the wing needs to be drilled too. on a bathroom scale the airframe componets weight 3.5-4.0 pounds.( less radio and engine)
I will post more photos tonight, bob
