ORIGINAL: iwant240sx
wow step 4.... how do i do that? blah im such a noob at rc...grr
You take the endbell off your motor by taking the screws off holding it. Then you take the armature out (don't loose the washers) and clean the armature, can, and endbell with motor spray or compressed air and some qtips. Then you relube both shafts on each side, relube bearings/bushings and you put it back togethere.
