RC Drifting Discuss all aspects of rc drifting here!
chassis cleaning
Old 08-16-2006 | 01:43 PM
iwant240sx's Avatar
Default chassis cleaning
my chassis is like super dirty how do i clean it?
Old 08-16-2006 | 01:58 PM
Default RE: chassis cleaning
air compressor and give it a quick once over or you can take everything apart and blow parts off with those cans of compressed air that you would use to clean keyboards and such and take a toothbrush and go over everything.
Old 08-16-2006 | 02:46 PM
JDM_DRIFTER's Avatar
My Method.
1. Blow dry the chassis to loosen up dirt and grime with the heat.
2. Brush it off with a 1 inch think hobby brush (paintbrush).
3. What ever is left between small areas are sprayed with chassis cleaner and wiped off.
4. Then I clean out the motor and relube it.
-JDM_DRIFTER
Old 08-16-2006 | 02:53 PM
iwant240sx's Avatar
wow step 4.... how do i do that? blah im such a noob at rc...grr
Old 08-16-2006 | 03:02 PM
aer-wubby's Avatar
ORIGINAL: iwant240sx
You take the endbell off your motor by taking the screws off holding it. Then you take the armature out (don't loose the washers) and clean the armature, can, and endbell with motor spray or compressed air and some qtips. Then you relube both shafts on each side, relube bearings/bushings and you put it back togethere.
Old 08-16-2006 | 09:47 PM
wats a good lube to use? how bout vasaline? or wd40?
Old 08-17-2006 | 09:01 AM
if those were the only choices i would go witht the wd 40. I am using trinity bearing oil on mine
