RCU Forums - View Single Post - hi every1, pics/ and need a lil help!!
Old 08-18-2006 | 07:21 AM
running_gag
Default RE: hi every1, pics/ and need a lil help!!
first thing you should swap your tamiya connectors with some deans connectors. also get your self a set of pinion gears so you can play with the gearing. If I were you I would also try a motor with more turns. torque is your friewnd here. take a look at a 19 or a 27 turn.
