RCU Forums - View Single Post - Help! please!!!
Old 08-18-2006 | 12:26 PM
125cchyperman
Default RE: Help! please!!!
If it shut's off when you hit the brakes but moves at idle without you holding having any throttle input then you have a problem with your clutch. The spring may have broken or your clutches may have melted and are frozen to the bell gear. Take the clutch bell off and look at the clutch. Thats more then likely your problem if you are experiencing those problems.
