Help! please!!!
WI
Ok my evader has been doing this for awhile and I was wondering what was wrong with it? Whener i start it up And I run around with it then I hit the brake and the engine quits? Please help I need to know whats wrong?
hi to adjust your idle there`s a screw on the carb you adjust but only turn finely quarter at a time whilst the car is running this should sort your problem.
Always laid back steve.
PA
If it shut's off when you hit the brakes but moves at idle without you holding having any throttle input then you have a problem with your clutch. The spring may have broken or your clutches may have melted and are frozen to the bell gear. Take the clutch bell off and look at the clutch. Thats more then likely your problem if you are experiencing those problems.
NC
HI! I GOT AN EVADER AND JUST THE OTHER DAY MINE DID THE SAME THING. EVERY TIME YOU TRY TO STOP IT GOES DEAD. WELL LIKE THE PREVIOUS POST IT WAS THE CLUTCH SPRING. IT'S AN EASY FIX FOR ABOUT $8.00 FROM TOWERHOBBIES. YOU GET THE SPRING AND SHOES.
