Mini Katana - Help Building
Hello,
I'm trying to build my first 3DFoamy kit, the Mini Katana. I have a couple questions about adhesive for the lamination:
1. The "Tips & Tricks" section at 3DFoamy.com says to use 3M 77 to laminate the layers. Is 3M 77 the same thing as 3M Super 77? All I could find was Super 77, and the print on the can says to not use it on Expanded Polystyrene Foam.
2. Based on posts in other forums, it sounded like the Super 77 would be safe, so I used it to laminate the fuselage sections. In my messiness, I got some in areas of the fuselage where it shouldn't be. What's the best way to get it off without hurting the Depron?
