Which Connectors?
I just ordered an E-flite Mini Ultra Stick, and a 11.1v 2100mAh battery. I've decided to go with the Accucycle charger, and get a balancing charger a bit later. So my question is, what connectors are you guys using? I'm leaning toward Deans, unless someone has any better suggestion, or reason I shouldn't use them in either parkflyers or glow. However the charger manual says it is not suggested that you solder your own leads. Not sure why they would have a problem with that, but what Else is one to do? Since NOTHING in this hobby seem standardized, I don't see any other choice but to solder my own. Am I missing something here?
