RE: Radio Gear Possessed... Help!!!
Are you using an external BEC or any type of external battery voltage monitor? I can only speak directly about the voltage monitor. On my Rap 60 I had an external VM plugged in and it was causing all kinds of noise\glitching. It was mounted away from everything and it still caused problems. I unplugged it and everything is good.
What type of radio gear? Channel?
On all my birds I use the Deans base loaded antenna. But the antenna wire coming from the receiver I always wrap in fuel tubing then wire tie the tubing to the frame. Knock-on-wood, but I haven't had a problem yet.
Joe
