RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 08-23-2006 | 05:29 AM
  #136
Don M.'s Avatar
Don M.
Default RE: Venus II
ORIGINAL: Nickolas
Hi,
I've noticed you installed the servos at the tail, how does the model balance with the OS-120? I plan to do the same that's why asking.
Rgrds,
Nick
Actually it is still a bit nose heavy. I have the battery as far back as I can get it without modifications. It flies fine that way, it just needs a bit too much down elevator inverted for my liking. I replaced the steel pushrods with CF ones. Not sure if that is lighter or heavier. Also as you can see I have an OS flex pipe on the engine which may add 1 - 2 ozs. in the nose. Whatever you do the 120 FS with the rear servos will be fine.
