I just..
Ground a little off (made it a little shorter) , then cut a semi-circular groove in the front to clear the hard point for the flying wires. Drilled a hole close as I could to the front (I cut thru the old holewhen I shortened it) and put 2 blind nuts in the ply plate that it mounts to.
