RCU Forums - View Single Post - looking for a good trainer
Old 01-08-2003 | 05:05 PM
Crash Master's Avatar
Crash Master
Default looking for a good trainer
Unfortunately Whirley Bird is probably correct if you were to try and buy a used balsa trainer.
However, if you can follow a few directions and can sweet-talk the owners of a local 7-11 store or gas station out of a couple of their old coroplast signs, you wold have most of the materials you would need to build yourself The Deb .
If you're just learning, The Deb would be an excellent choice as it is more durable than the traditional balsa and will survive the punishment a new pilot tends to put his model thru during the learning process.
As for servo's, you can always check ebay. you can find real bargins there sometimes.
Good luck,
