RCU Forums - View Single Post - Nitro-D Drift Vid
Old 08-23-2006 | 10:47 AM
PoweredByNitro's Avatar
PoweredByNitro
Default RE: Nitro-D Drift Vid
Thanks for the opinions, I like hearing the comments whether its good or bad. Magnet thanks for the headsup, I know I was kicking the tail out quite a bit and just loseing control not getting it into a nice drift. I did do a couple nice drifts there, so I know that these tires should work out pretty good for me. I'm thinking they would work really good for electric too. And drifting is kicking the tail out.. its just keeping the tail out while moving in the direction is something that will come with practice and a better setup. I was also running red pinions which is a taller gear meant more for high speed. I wasn't really haveing much of a problem with bottom end. Maybe going to the purple pinions will be a better idea. Couple questions..
Whats a good suspension setup.. hard or soft??? (I've done some research and seems like its more personal preference)
My steering was really sensitive and had it set so that I can turn either way pretty sharp. Should I have it set so its not so sensitive and not turn so sharp??
Thanks Guyz
