RE: Is this a good combo?
I have a Twist with a Thunder Tiger Pro.46 and 11-7 APC prop. It isn't quite 3D, but is prety aerobatic on high rates. There are faster planes, but this one is fast enough for me. One point of caution....this plane is a bit weak in the fuse right aft of the wing. Mine is the second one to snap in half making an extremely hard landing. Repaired easily though. If you fly a Stryker, you should hae a problem with the Twist.....
