RCU Forums - View Single Post - Comp ARF Flash update
Old 08-24-2006 | 07:56 AM
  #151
mc3854
Default RE: Comp ARF Flash update
I will be receiving my FLASH in a couple weeks. I will be using a P80 in it and was told by the rep that I didn't really need the wing tank! Sounds like I do need it to serve as a giant UAT in order to avoid the problem with the fuselage tank not emptying completely.
I am installing the Jet 1A trailing links on a BVM Bobcat to try to stop using so many of the breakaway plates! Even with gentle landings in grass they will eventually break. Do you think I should also be installing this gear in the FLASH?
