RCU Forums - View Single Post - Comp ARF Flash update
Old 08-24-2006 | 09:24 AM
  #156
digitech
My Feedback: (10)
Default RE: Comp ARF Flash update
ORIGINAL: Dave Wilshere
Sandor
No! the wing tank is the final tank!
Fuselage tank feeds the UAT
Regards
Dave
ok that explains why you dont have many problems then.
im think for the fuselage tanks as a single tank .
you can use only use about 70% of the fuel before foamy fuel starts filling the uat.
but can be solved.
since you empty the wing tank first , then the main tank fuselage you would have no problems.
good solved.
so gary at jet-tech has a job to do then.
he makes nice tanks.. the only bit i ever used you can see on the last picture i posted where the refurbisched flash tank
has a part of a eurosport jet-tech tank
