RE: HeliDirect BCP Skid Problem
I had the same problem.I just pushed the rod thru.It pressed up on the rods that connect to the body.One thing I did was to make a longer 2mm rod in place of the existing 2mm rod that connects the body and remove the rubber grommets.
