RCU Forums - View Single Post - Ultra Stick 40 Setup Question
Old 08-24-2006 | 11:30 PM
chashint
Default RE: Ultra Stick 40 Setup Question
This is just how it works on the 8U and 8U super when you use the glider mode.
The 8U manual eludes to being able to set it up without using the programmed mixes, I messed with mine a little bit and gave up on it.
If you figure it out post the setup.
